Rice Nuker
Let the Coal Roll!
Happy Friday to all fellow Mopar enthusiasts!
Well, got a 74 360, doing a basic overhaul and head work. The motor has 123k and runs smooth and clean like a top.
Want to clean the pistons nice. I want to clean the lands and the tops and the skirts.
Can I soda blast them? Will the soda clog up or cause abrasive action in the pin interface to the piston.
I found one total thread on here that had "clean pistons" in the subject.
The thread suggested brake cleaner spray and also soak in water a few other ideas.
So I am asking people in the know.
Has anyone tried transmission fluid soak? Maybe in a hot croc pot of transmission fluid? Anti-freeze in a crock pot?
Heard antifreeze cleans carbs great. I heard pine-sol in a crock pot cleans carbs great too. I've never tried anything on a carb other than a hammer:violent1:.
The lands are the biggest concern, because I have seen lots of people say use an old broken ring and scrape the crud out of the land groove. Sounds crude as hell and sounds like I will end up with a land groove which is out of tolerance. I understand fully that you cannot wire wheel majority of the piston due to deformation so.
Thanks!
Thanks!
