Cleaning a Fuel Filler Tube Questions
Hyper_pak
Old School Chrysler Fan
Desoto Texas
What are you FABO folks doing to clean these filler tubes?
Mine looks a little like the Titanic on the inside.
1976 Dart fold down rear seat so it has a big bend in the center.
It won't fit in my bead blast cabinet.
Any ideas?
Is the inside crusty.
You could fill the inside 1/2 full of blasting media and get your shake weight action going.
BUT... Be sure you get ALL the media out
Give it a try, I have heard of doing the same but with small pea gravel
Crusty as in rust? I would fill a 5 gallon bucket with white vinegar and soak it half at the time for several days for each side. It's cheap and it works.
