Ok so I listened to Larry at Clifford. He said the headers would fit w/ps, but the front header is bumping the ps box just enough to not fit properly. Any suggestions? Maybe I could indent the header. I don't know though
The car only has 80,000 original miles Rusty. Everyting I worked on has been original so far.
Motor mounts good? I'd contact the folks I got them from first if possible. If you have to dent the pipe, then to me it doesn't fit with power steering or somethings askew.Ok so I listened to Larry at Clifford. He said the headers would fit w/ps, but the front header is bumping the ps box just enough to not fit properly. Any suggestions? Maybe I could indent the header. I don't know though
I emailed larry eariler this week and asked him if they fit the 63-66 abodies with PS. He said they will for sure fit. Now i have my doubts.
They wont fit.I emailed larry eariler this week and asked him if they fit the 63-66 abodies with PS. He said they will for sure fit. Now i have my doubts.
My friend had cliffords on his slant six with PS in a 74 valiant, clears well, i i think your motor mount is too low/worn out, you have the later k member with spool type motor mounts you can loosen the mount on driver side use a block of wood and jack to lift the motor up once you loosen the motor mount, or lift the motor with a cherry picker from the two bolts on the then tighten up the motor mounts to the new adjusted heightThanks Charlie, I'll try a mount and see what happens
Larry is full of dog dodo!
Or doodoo, yeah. Same ol' Larry; same ol' Clifford: full o' laffs (for them) wasted money-effort-time (for their customers).
Ok, reporting back. I installed a new Poly engine Mount and it did make a difference. A very, very small difference. The header still makes contact with the Power Steering unit, which is not good, but it dropped in enough that I believe with a Remflex Gasket it could work. /QUOTE]
Sounds like you're close. Read post 17. You can get a little more clearance by moving the thru bolt up in the slot.
