Does anybody have any experience removing a Clutch/Brake Assembly from a 69 Dart? I am trying to remove this assembly on a 1969 Swinger. I have all of the bolts removed and have loosened the steering column. But the assembly won't pull back far enough for the bolts that secure the master cylinder, to clear the firewall. It is hitting a bracket that seems to be attached higher up in the dash. Do I have to remove the instrument cluster and then will be able to see where this bracket attaches or am I missing something simple? Also will I have to remove the steering column or can I just pull it down enough to get the assembly out?
Thanks for any advice.
