I looked at a lot of past messages and didn't see this one. 70 Duster, 340 4 spd. The rod that goes from my clutch pedal to the z bar hits the bottom of the hole going through the firewall. Does not appear to be any adjustment for this? Looking at my z bar it appears the arm is bent in just a bit. I may be able to bend it to get the rod a little higher and more centered in the hole but I don't think it will be enough to prevent it from rubbing. Doesn't show it very well, but am attaching pictures of the rod going through the firewall, and also of my Z bar, do they look like the correct parts?
