rob_robinson87
Ok, now that I have my new battery and it is charged (putting out 12.7 volts without car running) I was looking to where I can tie in my electric choke. Upon checking for power with key on, I find that the voltage at the voltage regulator (center pin) that connects to the key on and to alternator field, drops to 11.3 volts when the 12+ (key wire) connector is attached to the ballast resistor (and coil). Should I see that much drop? Since that same circuit runs to the alternator, I'm afraid that it will affect how the alternator charges. I have made some upgrades such as headlight relays and the jumper from the alternator to the starter relay to ease the interior wiring.
As long as the ballast is unplugged, I get the full 12 volts at the voltage regulator and of course, the alternator. Before I start ripping wiring out, I thought I would check to see if you think that the ignition switch, or coil could cause this, or would it be deeper into the wiring (such as the dreaded bulkhead connector).
