Cold Case 26in Rad fitment
Heating / Cooling / AC
  1. C2ndLTpigeon
    C2ndLTpigeon Mopar or no Car! FABO Gold Member
    466
    111
    May 18, 2019
    Indio California
    Local Time:
    10:57 PM
    I received my cold case 26 in rad yesterday, and have began the installation in my 73 valiant.
    It looks like I will have to modify it with some holes to mount it to the car as the current holes are not even close to lining up. Has anyone else installed on in a 73+ A-body that can provide pics on bolt modification? Another thing I wanted to see if there is a way to use a stock radiator shroud? If not does anyone have a recommendation on a direct fit shroud?
    I have also attached photos showing the space between the Radiator water pump pully. I ordered a Haden low profile clutch to run with my stock a/c car 7 blade fan.
  2. famous bob
    famous bob mopar misfit
    19,385
    8473
    Aug 14, 2011
    okla
    Local Time:
    12:57 AM
    I do believe you are going to have trouble w/ the clearance !!
  3. Dana67Dart
    Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
    6,170
    4026
    Jul 16, 2017
    Northern Colorado
    Local Time:
    11:57 PM
    Maybe can help.
    @ColdCaseJoe
    If it was me I would gather up a the parts I want to fit together, see where the want to fit and drill the radiator (with CCs blessing so you don't void the warrentee etc) flange rather than the cars flange.
  4. Dana67Dart
    6,170
    4026
    Jul 16, 2017
    Northern Colorado
    Local Time:
    11:57 PM
    Loose the fan clutch, no issues. Clutch is an efficiency (MPG) thing not a cooling thing
    • Agree Agree x 1
    • dano
      dano Evil Handy Man
      3,705
      1563
      Aug 22, 2005
      Gresham, Oregon
      Local Time:
      10:57 PM
      I can't comment on the 26" fitment but its not overly uncommon to have to fit most brands of radiator. The 70-up 22" Cold Case I installed in my 69 fell right in, the Champion I had before that did not.
      For the stock shroud I rived on some thick, black, rubber garage door seal that had a lip I biased against the radiator tanks at the top and bottom to seal the gaps. Seems to work well.
      The thicker core radiators stick out far more that stock. So you will need to fit your fan accordingly. I think I have the same 2-3/4" space you had and ended up running a 18" flex fan. But I have power steering so there is lees room for me to fit a fan between the core and the PS pulley.
    • C2ndLTpigeon
      466
      111
      May 18, 2019
      Indio California
      Local Time:
      10:57 PM
      Yea that was one of my concerns about drilling holes. I do not want to void the warranty or the ability to send it back. I was going to go with a flex fan but decided to go with a clutch after reading that the Haden 2947 would work, so I ordered one and was going to check fitment when it arrives today.
    • mopowers
      mopowers Well-Known Member
      5,431
      2464
      Feb 15, 2006
      West Sacramento, CA
      Local Time:
      10:57 PM
      The 2947 clutch is 2.7" tall. Looks like you don't have that much space.
      • Agree Agree x 1
      • dano
        dano Evil Handy Man
        3,705
        1563
        Aug 22, 2005
        Gresham, Oregon
        Local Time:
        10:57 PM
        Why I have one and a new clutch fan sitting on my shelf now....
        And that thing is so short it's damn near impossible to install then add a shroud to the mix.
      • famous bob
        19,385
        8473
        Aug 14, 2011
        okla
        Local Time:
        12:57 AM
        I`M RUNNING THE 2947 AND HAVE MORE ROOM THAN HIS PIC, "LOOKS LIKE " , I EVEN CHUCKED THE CLUTCH UP IN MY LATHA EXACTED THE FRONT FINS, TTHEY WEREN`T ALL EVEN ,(CAST PART ) , think I took about .060 off to true them up.
        A straight driven belt fan is worth about 6-8 over a clutch set up on mine , but the clutch is supposed to be about 20h.p. better .
      • mopowers
        5,431
        2464
        Feb 15, 2006
        West Sacramento, CA
        Local Time:
        10:57 PM
        Yep - it's a bit of a pain to install. I've got one as well. In my car, I have to install the radiator after the fan/clutch. Total pain in the ass. The OP just flat doesn't have the space.
        It's a shame there's so much offset built into those mounts on the radiator. Looks like they could get another .5" by just welding the side brackets further up on the core.
        • Agree Agree x 1
        • famous bob
          19,385
          8473
          Aug 14, 2011
          okla
          Local Time:
          12:57 AM
          IMG_0150 (1).jpg IMG_0470 (1).JPG Fix ur shroud to make it split in the middle on the sides , bolts / studs are abitch to get in , but I`ve gone both ways on them.
        • C2ndLTpigeon
          466
          111
          May 18, 2019
          Indio California
          Local Time:
          10:57 PM
          Bummer, looks like I might just stick to my stock rad then. I was really looking for something that didn't require much modifying. Appreciate the help and tips.
        • dano
          dano Evil Handy Man
          3,705
          1563
          Aug 22, 2005
          Gresham, Oregon
          Local Time:
          10:57 PM
          Don't you have a B/RB?
        • Mike69cuda
          Mike69cuda 64 is the new 17 FABO Gold Member
          2,185
          1718
          Jan 2, 2018
          Overland Park Kansas
          Local Time:
          12:57 AM
          I have a cold case 22 inch 70 up radiator in mine and it does take up some extra space. The 2947 is definitely I challenge to install with a 7 blade fan. Might be easier with a 5 blade.
          • Agree Agree x 1
          • Ccas
            Ccas FABO Vendor FABO Vendor
            264
            189
            Dec 7, 2016
            Hatfield, PA
            Local Time:
            1:57 AM
            The 26" unit we made was patterned with a B and E body. I don't think we ever got our hands on a 73 Valiant with a 26" radiator support. However, if you have an original 26" shroud, I think it's going to be an easy bolt on. You might just need to drill holes in the rad brackets to mount.
            If by any chance you or anyone else has the original radiator, we'd love to be able to borrow it so that we can make a specific 26" A-body unit that is a true bolt on.
          • str12-340
            str12-340 FABO Gold Member FABO Gold Member
            1,777
            1048
            Dec 26, 2012
            Vashon, WA
            Local Time:
            10:57 PM
            Did this car come with a 26 inch radiator???
          • yellow rose
            yellow rose Overnight Sensation FABO Gold Member
            27,953
            24228
            Jun 19, 2015
            Central Washington
            Local Time:
            10:57 PM
            Just drill the holes. A stock radiator isn’t close to what you now have. I had to do the same thing. It pissed me off, but to get a real radiator in there that’s what you do.
          • yellow rose
            27,953
            24228
            Jun 19, 2015
            Central Washington
            Local Time:
            10:57 PM
            I have a factory A body 26 inch radiator. The core got shredded but if you want it PM. I’d LOVE to have a bolt in 26 inch radiator.
            • Agree Agree x 1
            • C2ndLTpigeon
              466
              111
              May 18, 2019
              Indio California
              Local Time:
              10:57 PM
              Gave my stock one a nice paint job, as well as the shroud. There is not enough clearance with the Haden fan clutch so looks like I will stay stock for now.
            • famous bob
              19,385
              8473
              Aug 14, 2011
              okla
              Local Time:
              12:57 AM
              u could go to a full mech. fan w/o a clutch ---------- might need a spacer , most likely 1/2'' or so.
            • famous bob
              19,385
              8473
              Aug 14, 2011
              okla
              Local Time:
              12:57 AM
              What kind of real rad. do u have / any pics ?
            • yellow rose
              27,953
              24228
              Jun 19, 2015
              Central Washington
              Local Time:
              10:57 PM
              I can take some pictures when I get back. Getting ready to go out of town. I was using it on my run in stand and it took a fan to the core so it’s had it. But if ColdCase can use it to make an actual drop in fit 26 inch A body radiator I’ll gladly send it to them.
              • Like Like x 1
