HTMLmopars
Just picked up the summit 50052 cam kit for my 318, since I have a stock cam and a lifter tick, I figured I'd upgrade the cam while also fixing the noise. I just pulled the trigger on buying the cam (specced from the original 318willrun post), and then started thinking more about everyone's experience with bad lifters nowadays.
I'm debating on whether I should cancel/return the cam and go with higher end cam and lifters, maybe from racer brown or oregon cam grinders. Or get a budget summit cam and get nicer lifters from a lower volume manufacturer?
Any guidance or opinions on modern flat tappet lifters would be great!
Links to threads that I overlooked in my searches are also appreciated, I don't need y'all to be broken records just because I can't use the search function properly
