BIG-B-Barracuda
73 scamp quote]
Does it have a foorshift column?
yes it has the floor shifter AUTO -
73 scamp quote]
73 scamp quote]
yes it has the FLOOR SHIFTER - AUTO ..
Do you know what they would want for the column? And is it a smooth column without the indicator and shifter arm?
not quite sure i understand you
Is the column in the scamp there and if it is do you know the price they would want for it?
The Scamp column will not fit as an assembly. Insides may or may not be alike.
The member on here that sells the flip top fuel cap adapters makes them out of Delrin. If the pin isn't available maybe he can see about getting some made. Maybe it will become his next product.
http://www.forabodiesonly.com/mopar/showthread.php?t=53282&highlight=delrin
I dont understand what you are sayin about the column?
Subscribed to watch and learn.
Big B, You could eliminate that troublesome coupling with a swivel U Joint. You should be able to find the one you need at Summitt or Jegs.
