fratzog lover
This wont ease your pain, but the factory didnt exactly spray the underhood area to "show car" quality standards.
Hey Darren . I worked in GM's Oshawa car assembly plant#1 Paint shop in the eighties and worked as a line sprayer, one of the jobs i worked on was under hood color in the prime booth . We hosed the paint on. as other guys said, they were more worried about thin paint than runs in the motor compartment we were running 80 units per hour that figured out to about 50 seconds to paint your side of the car , the hood was on . The guy on the left raised the hood and installed a prop rod to hold it up , applied paint to the bottom of the window opening ,left side of the shock tower ,firewall ,inside edge of the left fender then across the rad support then across the rear of the hood up the inner edge and then across the front of the hood so as you can see there wasn't time for much finesse .That was when they first went to base/clear coat and they never applied clear to the engine compartment , that was when we where building the Pontiac J6000 I hope this sheds a bit of light on auto assembly, they were all about quantity and not so much about quality.So I'm sure your car looks better than it did when it was fresh of the line. Good Luck . Bob
Looks dry to me and sanding - buffing may not help the problem - should have reshot it - engine bays are hard to paint due to many angles and not much room to work in
