71Scamper
Mopar runs thru my veins!
where can I get a new steering column o ring for my 71 Scamp. I'm looking for the one that gets sandwiched in the lower column to firewall plate. Thanks!
Suggestion: measure i.d.,o.d.,thickness. Take measurements to place that makes hydrolic hoses or a truck service center or Clutch & Brake in Salem. Should have them. If not, take measurments to machime shop and have one made of Nylon. Hope this helps, Tom. Any Scamp parts for sale?
You talking about the boot?
Good Idea on Brake and Clutch. I'll try them. What are you looking for as far as Scamp parts?
No boot. It is a big rubber O ring that is clamped between two plates and then the plate assembly is bolted to the firewall.
This is the seal that I am used to there.
http://www.ebay.com/itm/DMT-BLACK-A...Parts_Accessories&hash=item53dff2e1ab&vxp=mtr
Hi Scamper, I am looking for a-piller plastic moulding #2811555 right side or a pair in ef-3 green (lt.green met.),also, front windshield outside moulding clip. there is more but my senior brain is not functioning today. thankyou, Tom
Hi Scamper, I don't have any a-piller moouldings to trade as one of mine is cracked. If you have black seatbelts (front) I could use them. I will try Amherst Swap at the end of the month and get black ones to trade or green ones for myself. I used to sell there years ago, never had any luck. Gary Leplante is usually there. Thanks, Tom
There's another seal that is a simple o ring that goes where that triangle plate attaches to the steering column tube.
