column to floor swap
Moparguy45
Active Member
Howell
im looking to buy a 69 dart with 3 speed manual column shift but it comes with a a833 and i was just wondering how much of a job would it be to make it floor shift. any help would be great.
biggest issue would be installing the floor hump.
Bellhousing may be different from 3 spped to 4 speed.
What all do you have? Just the tranny? The hard part is getting all the parts together. You are going to need a lot of small parts. IE, shifter, shift rods, clutch peddle, linkege, Z-bar, Floor hump, ect. Once you have all the parts together the swap is not all that hard. Installing the floor hump and the Z bar brace is going to be the most criticle part.
