Combination for a peppy 340
Looks nice! Will your lifters come out with the heads on? I have the same lifters in a 273 and they will come out with the heads on. Some have reported that the Morels won't come out with aftermarket heads. No biggie either way, but try it if you don't have the intake on yet and you'll know if you ever decide to swap cams.
I don’t think I can with the Edelbrock heads but I’m sure something could be “engineered” to keep the lifters up so the cam can be pulled. I think the springs on these heads support .575 lift. So I can’t go a ton larger. Not to say they can’t be changed too.. this will be a fun hot rod and I can’t see wanting to go more.. but I’m sure we’ve all said that before lol
Most guys tend to over cam an engine, and as many others have already stated neither of those cams will be that much fun on the street with a 3.55 gear.
Also, you may or may not know, but the way a roller cam works it probably has the same effect as a hydraulic cam that's got 10 degrees more duration.
If you want a nice street grind, find a hydraulic roller that has 228/234 at .050"
Tom
Tom
The cam that’s in this engine has that.. 227/235 @ .050
Just a little update.. the 340 is nearly ready for me to drop in the Dart. We went ahead and opened it another .010 for a total of .040 over. KB243 pistons, Edelbrock 6017 heads, howards hydraulic roller cam with .525/.530 lift.. edel air gap intake. Harland Sharp rockers… the snowball effect definitely happened with this engine. I’m gonna use Doug’s D453 ceramic headers. I’m happy to report that the lifter bores were okay with the morel lifters and didn’t even need to grind the ribs in the valley for them to fit. Online calculators put the compression at 9.75ish static an around 8.47:1 dynamic with that camshaft.
Should make for a spicy ride with the 4spd and 3.55 gear… my clutch is just a McLoed street clutch but I’m runnin just a regular cooper rear tire so it’s gonna blow the tires fairly easy. It probably would be smart to step that up to the 500hp rated one for some insurance.
Here’s a few shots. I went by today and brought a 68-69 timing cover and balancer since my 68 Dart uses the iron water pump a the original cover was the later driver side timing mark version. Just have to finish assembly, measure for pushrods, freshen the orange paint job, and other small details..
View attachment 1716492038View attachment 1716492037
I run that cam in my 318 with 1.6 rockers and trick flows.. i have been pretty happy with it...
This is what it sounds like if interested (ignore the header leak, long fixed)
Should sound a little milder in your motor due to cubes though
Sound clip
Sounds righteous! I’m gonna see low long it takes before the current flowmaster dumps before the rear axle will irritate the hell out of me lol
They will sound great... I had put in Gibson MWA mufflers (mufflers with attitude) And honestly it was crazy.. it might as well have been open headers, and that's 3" to the bumper...
Now i have hooker.. i think aeroflow mufflers.. really happy with them...
P.S. i had bought a pair of summit mufflers to quiet it.. and that ended up costing me months of crap and $2000 in parts trying to fix a problem that ended up being bad mufflers. good times.
Currently it has a H pipe system that flowmaster offers. Total hack job on how they mated the H pipe to the pipes off the manifolds.. I may just get a summit kit made to bolt to headers and reuse my current mufflers.
I made my kit out of a amazon 3" pipe kit and just welded it up (except mufflers/tail pipes..) i take apart my **** so much that a full welded exhaust would be bad :)
Just remembered.. i also put resonators in the tailpipes to calm it a little more.. it had this RASPY sound that i hate.. like a old mans 78 chevy pickup..
I have a b-body though.. i don't think there is room in a a-body
Dumped flows was always a favorite sound of mine.. I won’t be driving daily so it won’t be like I’m in traffic and the drone will beat your brains out.. I kinda dig the black widow muffles from the clips I’ve watched on YouTube.. we’ll see how it turns out after then decide to keep them or try something a little less drone prone
I always ran dumped flowmasters, but now i'm old :) I wanted quieter and less fumes... the main thing is i leave for work just before 6am.. and i like my neighbors.
That is one perk of living out in the country lol. I work a mix of day shifts and night shifts.. I leave for work at 3:45am when I work day shift… that wouldn’t bode well if I had close close neighbors. if I did drive it to work it would be when I’d work nights.. it would be maybe 1-2 times a month during the cooler months.. which isn’t many in Louisiana.
Nice, i used to be in the country 20 years ago and now it's all new subdivisions and **** near me.. i kinda hate it cause people suck.. My neighbore are very cool though. I never get why people post videos of a loud car with "**** my neighbors" and stuff... i have to live with these people, i at least try to be cordial.
BTW.. i'm jealous.. i wish i lived somewhere warm, here when november rolls around i just shut down. I have a huge list to do on my car and i won't even touch it for 3 more months
The high today and tomorrow will be the upper 70s… not very Christmas like but.. beats being buried in snow I guess
Any SA carb I have ever seen has been a disaster. I would use a trusted and known carb first, then try the 670. If it works correctly it won't be too big---lol. A 360 cube SBC making close to 600hp only moves about 705cfm. Your engine will likely move about 480-500cfm @ 390-410hp. J.Rob
I bought the carburetor from a close friend of mine with intent of putting it on the 318, which would have been fine. The 670 would be so the “new” engine could be in a running and driving state. It’ll definitely need more.
It’s a trusted carb that a close friend offered to me because he went to a stroker motor in his 65 Mustang. He drove for several thousand miles with the 670. We shall see. Hopefully it won’t be a complete dumpster fire
Just Mopar Joe is building a very similar setup but in a 360 configuration and the whole reason why I even decided to try to see what figure it was gonna be was to compare to his 360.. I’ll have to plug in the numbers to another ones to see what I get. He mentioned how dynamic can really tell you the story on using pump gas or needing more than that. I was confident that I was pump friendly because I’m not using a crazy combination of piston and cylinder head in addition to the heads being aluminum.
It’s not dynamic compression that matters because it needs to be calculated at varying loads and engine speeds. The term is being used incorrectly.
Look at your EFFECTIVE compression ratio. That’s what matters. And how you build and tune the engine.
