1. drewmac
    drewmac Well-Known Member
    353
    116
    Jun 7, 2012
    Lacey, Wa
    Local Time:
    5:36 AM
    Can I use a floor shift upper (part right under steering wheel) manual column on a column shift ( below the rotating part with the lever) lower power column to make a floor shift power steering column? I have both and was hoping I could mix n match them to make what I need. Sorry I this is vague. I'll see if I can add some pics to show what I mean.
  2. kursplat
    kursplat FABO Gold Member FABO Gold Member
    4,278
    3225
    Aug 24, 2010
    so cal
    Local Time:
    5:36 AM
    i'm guessing you are talking about the column collar? in general, yes they interchange
    • Like Like x 1
    • kursplat
      4,278
      3225
      Aug 24, 2010
      so cal
      Local Time:
      5:36 AM
      • Like Like x 1
      • drewmac
        353
        116
        Jun 7, 2012
        Lacey, Wa
        Local Time:
        5:36 AM
        Thanks guys. This helps a lot!
