rmchrgr
Skate And Destroy
Comp Cams CL20-212-2 cam and lifter kit. This is the 268H cam for LA small block engines, 273-360. Good, mild street cam.
Specs as follows:
Hydraulic flat tappet CRS 268H-10
Basic Operating RPM Range 1,500-5,500
Int. Dur. @ .050" Lift - 218º
Ex. Dur. @ .050" Lift - 218º
268º Advertised Duration
.454" Valve Lift with Factory Rocker Arm Ratio
Lobe Separation (degrees) 110º
Comp 901-16 springs suggested but I believe you can use stock springs and other related parts and still be OK.
This is a brand-new-in-the-box kit that retails for over $215. $200 shipped. Parts are located in Huntington, NY 11743. PM with questions.
Specs as follows:
