gzig5
I fell into a good deal on a set of new 821-16 lifters and I'm not seeing much review info on them. I was a little surprised there is no reduced band on the body like many lifters have. They are cylindrical. Anything to watch out for in using this lifter?
I've been leaning toward a SFT cam for the upcoming improvements and now I can't use lack of parts for an excuse. Should give a higher top end for the 340 and maybe 20hp over a hydraulic cam that gave similar lift and timing at the valve? I know you can't compare solid and hydraulic cam specs straight up.
