[SOLD] Comp Cams 928-16 dual valve springs and Comp Cams titanium 10 degree retainers
Rocket
CT
I have a lightly used set of 16 Comp Cams 928-16 dual valve springs and Comp Cams titanium 10 degree retainers. These were lightly used for ~ 600 street miles. I ended up going with a different cam set up that required different springs.
Outside Diameter of Outer Spring (in): 1.550 in.
Coil Bind Height (in): 1.160 in.
Spring Rate (lbs/in): 354 lbs./in.
Inside Diameter of Outer Spring (in): 1.150 in.
Inside Diameter of Inner Spring (in): 0.795 in.
732-16 Titanium retainers.
Uses 10 degree valve locks.
Summit price for these parts is $450. I will let them go for $240 shipped in the lower 48 states. I will also ship internationally with the inclusion of the incremental shipping and handling cost.
I unfortunately do not know the answer to that question. They should work fine if the installed height and open and closed spring pressure are suitable for the cam and head combination you have.
