when I build my engines , I check each lifter in the hole and hones them until they move freely. and clean the block and make sure the cam is lube properly. if you have really hard springs they recommend you break in cam with lighter springs. I ve never had a cam break in issue yet im over 50I watched that last night. I was hoping the guy would ask why so many of their cams get wiped out on break in![]()
With all Comp cams?I ve never had a cam break in issue yet im over 50
no with other brands also last 3 engines this one was regrind for , the other 2 was international v8With all Comp cams?
I just wiped out a 360 cid rebuild using, Comp Cams stuff , very doubtful if Ill return to Comp Cams, the Customer Service and Warranty folks, just jerked me around on the phone to say, it was my fault! Going to HOWARDS for version 2I watched that last night. I was hoping the guy would ask why so many of their cams get wiped out on break in![]()
Have you used Comp Cams products recently (withing the past 18 months) ?when I build my engines , I check each lifter in the hole and hones them until they move freely. and clean the block and make sure the cam is lube properly. if you have really hard springs they recommend you break in cam with lighter springs. I ve never had a cam break in issue yet im over 50
ns1rm21 had two Comp 268XE BB mopar cams go bad immediately on run stand within 2 week period about 2 years ago. Then ran 20+ year old NOS MP cam and no issues. Many miles since.
Just got a Comp multi-key BB timing chain to degree cam with about 4 months ago. Keys were way off.
No more Comp.
So, your comments are, NOT, related to the Comp Cams discussion, correct ?no with other brands also last 3 engines this one was regrind for , the other 2 was international v8
China Cow Churned!You see, the secret ingredient for the cam lobes is butter. The lobes are made of butter. LOL
