Comp pro magnum side2side clearance.
340Duster247
Calgary
Just curious what you guys run for comp rocker side clearance. Street/strip car.
I've searched but I mostly get details for aluminum rockers not steel.
TIA.
Hughes/Harland Sharp for hold downs.
The did see another place that had them cheap but it was a private fella doing them. I can’t remember the place.
To tight and they will rub something or each other and make problems. BTDT
Anyone know why comp says at LEAST .030 in their instructions?
Seems excessive
They expand more than aluminum.
I wouldn't run .030, because you'll hear them clicking.
I've run them .015 hot... but .020 is probably a better recommendation ...but if you think about it..its splitting hairs.
It was a completely different rocker set up, .015.
Mopar has these. I milled down stock spacers for clearance.
