I have for sale a '74 LA 360 engine- Date code is 4/22/74, so for you late '74 model year guys this could be a proper date code engine. :cool:
Engine was originally out of a truck of some kind, has a truck pan and the exhaust valve rotators. The gentleman I bought it from got it out of a pick a part type yard. Its a high mileage engine, but it turns freely and has no obvious damage. I didn't see any stamps on the tops of the pistons, I would guess its still standard bore. I did a leak down test on it awhile back, it had two low cylinders with blow-by past the rings, the rest checked ok. I was going to try and get it running but its probably a little too worn out for that. Has 974 heads on it (1.88/1.60 valves). Most of the parts are pictured, its pretty much a complete engine with 2v intake, I can even throw in a 2v Carter if you'd like. I have the timing cover, water pump, damper, flex plate, and passenger side exhaust manifold, driver side manifold seems to be missing.
Engine is located in the Sacramento area, I can deliver for gas money within an hour or two at the most. I can crate it for shipping, lets say $50 for crating and delivery to a shipping terminal in West Sacramento. I do have a shipper I've used before if you need one.
$300 obo, email or PM me with offers or questions through my profile.
Thanks! :thumbup:
Thanks! :thumbup:
