[SOLD] Complete 318 with 4 speed
theidlemind
Member
Bradenton
Older 4 barrel (Carter) 318 (points) with 4 speed attached. Shift lever is missing, has reverse lockout (lift to shift into reverse).
Transmission is the aluminum case, maybe overdrive.
Unknown condition........ but complete.
Sarasota, Florida 34243
750$
Crazy it has a GM carb- Rochester Quadrajet and a GM Alternator. I have never seen that. According to the levers on the trans. it is the OD 4 speed.
Quadrajet replaced the Thermoquad in about 82? Until the throttle body injection came on board in about 88.
not original carb//that carb had electric choke (removed)and under the throttle linkage is an EGR port
he did mention "rat rod":lol:
It's an overdrive, the 3rd to 4th lever is flipped. Interested in selling the Quadrajet separately? They're not too bad of a carburetor.
Let's cut back on the chit chat fellas. This is a sale thread. Thanks
750$
I’m marking this sold just to get it off the list.
I pulled the intake and valve covers and discovered a set of 68-70 340 heads. Gonna rethink this situation.
