[FOR SALE] Complete 73~76 V8 BBP Disc Front End
junkyardhero
Los Angeles
complete 73~76 disc set up with a V8 K-member, including factory swaybar. everything you need to upgrade any 67~76 a-body. pulled out in favor of an aftermarket set up. the upper & lower ball joints are still in good condition and have lots of life left, you can run the upper control arm bushings as is, but the lower control arm bushings will need to be replaced.
included but not pictured are splash shields, rotors and calipers. the rotors could be turned and the calipers are good for cores.
$1200
located in los angeles, delivery available. willing to ship but it's going to be expensive. if you have any questions or need more pictures feel free to ask.
here's a pic of the rotors & calipers.
rotors are good to run as is or take a light scuff. the bearings are bagged and tagged. the calipers are cores.
sorry fellas, the band broke up. K member wanted to play more navel gazing prog rock and the control arms voted him out.
the line up of the new group is:
upper control arms, lower control arms, spindles, 11" caliper adapters, strut rods, sway bar & brackets, distribution block and prop valve, rotors & caliper cores with splash shields.
a ticket to the show is now only $700
and this VIP package includes:
good condition upper and lower ball joints, good upper control arm bushings, tie rods and sleeves, a good idler arm, and ALL of the hardware-- t-bar adjusters, UCA cam bolts, shock bolts, LCA pin washer and nut, caliper adapter bolts, caliper attachment hardware, splash shield bolts, spindle nut, washer and cage, lower ball joint bolts, strut rod hardware and even wheel bearings.
