jhdeval
Okay I have a 65 Barracuda with a Slant Six. I bought a compressor with mounting bracket but I seem to be having some issues.
Is this the right bracket? I was able to line up the first two of the holes to my water pump second and third bolts from the heater hose but the swinging third mount would not line up to anything. The swinging third bolt appears to fit nicely on the front mount of the boxed support but it is not long enough.
Also the rear support did not line up anywhere. The rear support that I have is designed to attach to the rear and head down to a boxed support below the compressor. It gets close but not close enough.
