[SOLD] console brackets and auto shifter mechanism
khaley71
Maryland
Selling console brackets and shifter mechanism with part of the linkage I think this will fit 67 up to 74 a bodies. I don't think the shifter mechanism is usable, the mounting tab on the bottom center of the main console/shifter bracket was cut off when it was removed from the car by the previous owner. Should be easy weld a replacement tab on. I can cut the remaining floor pan off the brackets or leave as is. $75 shipped in the lower 48
hi i see in the photos there is a switch on this unit do you know the name of this switch? i have center console that i missing this item.
