Convert REAR to 4.5"
dust
B5PistolGrip.com
US
It looks like all you'd need to do is bolt-in the axles (w/green bearings) with matching brake assemblies and wheels to convert to big bolt pattern, Will the brake line plumbing connect up fine?
I'll need 29-spline 1973-76 A-body axles I assume, right? Car: '72 Duster 8 3/4.
http://www.bigblockdart.com/techpages/875axle.shtml
8 3/4 ?
you don't need to use green bearing if ya have all the stock style stuff. you'll need to either cut down c-body/truck axles or buy aftermarket from moser or yukon.
hey man are these axles you are talking about the ones that you just need to redrill your drums?
The Yukon and moser axles need different drums as they have a different offset. you will need 8 1/4 drums and backing plates with 4.5 bp, or 8 3/4 b & e body stuff
I had these on my cuda before i went to rear disc.
