Convertable floor shifter and linkage wanted
Gabby1959
Member
Oklahoma City
Looking for a floor shifter and linkage that will work on a 1965 Imperial. Presently has a column shifter, and a 727 TF, any leads or comments welcomed
If I am not mistaken your 727 is a dual cable style. If so then the floor shift from an A, B or C Body should work with the appropriate length cables. Alternatively, if you swap your 65 727 for a 66-later 727, any floor shifter can be adapted.
You need to start a "wanted" thread. PM sent
