Converter upgrade
63dartman
rio rancho, nm
Would this be a good upgrade to a stock converter?
Hughes Street Master 2200-2500 RPM Stall
The Street Master converter was designed for the driver who is looking for that competitive advantage. By raising the stall RPM you can eliminate that slow, sluggish start. Recommended for stock to slightly modified engines to achieve performance, along with a smooth idle when the car is in gear.
I am running a 360 with 9.5 - 9.8 compression. 8 3/4 with 3.23 904TF. rear will be getting some 3.55 or 3.91 in the future.
lol, I knew I missed something.....I am running a lunati cam. .454 intake .475 exhaust 213/220 at.050 256/262 advertised. 1.5 ratio
Looks like it should work good to me. That's a small cam so it don't really need a high stall converter but a little more stall speed always helps.
