Converter weights
1971Plymouth
Kansas
I recently bought a 10" converter for my 360. It did not come with weights on it. Where should the weight be placed and how heavy does it need to be?
X3. That way if you decide to swap in a 340/ etc neutral balance engine, you only need to use a different flex plate
X5. Pop had a cuda with a 360 that replaced the original 340. Picked it up cheap because it vibrated like hell and guy couldnt figure it out. B&M external balanced flexplate for a 360 and problem was fixed for $75
