Cudainashed
I am getting ready to replace the floor in my 68 Barracuda and I am interested in seeing how people built their door braces and how they braced their bodies before removing their floors.
I just used a x brace for the floor pans on the hardtop(door stiker/latch to opposite door lower hings mounting bolts), but on the convertible I made sure to use a V style brace going from the door striker/latch area to the top of the pillar post and the bottom section from the striker/latch to the top hinge bolts . that kept the windshield in alignment with the door opening the X brace was only when I flipped the car on it's side to remove bad metal.
since my torque boxes were solid I didn't notice any extra flexing of the body once I put in the V brace.
it seems I can only find some of the V brace pic's hmmmmm
Sure can. they're not really good ones since I didn't think about taking pic's of the setup though. basically I welded a 3 or 4 inch section of 3" angle iron onto the square tubing and used the latch as a pattern for drilling the holes to screw it into. I even used the door latch screws to mount the back piece to the door jamb.Can you post some pictures of how you attached to the rear of the door opening on the convertible?
Thanks
