Converting '67 Dart trim to '68 Dart stainless trim "where to buy clip studs"
duster360
Alabama
I am converting my '67 Dart windshield gasket and trim to '68 Dart gasket and stainless trim. Anyone know where I can get the studs that go around the windshield that the clips attach to?
I thought the factory cars had small studs that the trim clips snapped onto?
Factory cars had studs but you will need screws. They will be supplied with the clips. I did this swap with my 67 cuda.
The factory used studs on a lot of body trim including vinyl top trim but only where a plastic clip was used. Window reveal mouldings all used steel clips and special screws.
Common hardware store screws will work if you use #6 X 3/8 round head phillips.
the special screws are #8 diameter with the #6 screws head. I hope this explains why clip packages include the screws.
Ok. I appreciate the info fellas. I will be ordering the clip package with the screws. Thanks.
