Converting a manual top to a power top
Convertible A-Body Mopar
  1. lilwarlock
    lilwarlock Active Member
    25
    26
    Jan 16, 2013
    MA
    Local Time:
    9:40 AM
    Has any member changed a manual top to a power top? If so, how difficult is it and does anyone have any pictures of the work they have completed the power top conversion.
  2. Cuda Al
    Cuda Al Well-Known Member
    1,502
    1745
    Oct 21, 2007
    Lompoc, CA
    Local Time:
    6:40 AM
    Year make and model?
    Alan
  3. Cuda Al
    1,502
    1745
    Oct 21, 2007
    Lompoc, CA
    Local Time:
    6:40 AM
    I would assume that if a power top was an option on that car then it would just be the pump, cylinders and hose.
    Alan
  4. Dana67Dart
    Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member
    7,450
    5087
    Jul 16, 2017
    Northern Colorado
    Local Time:
    7:40 AM
    Im guessing there would be some counter weight springs and the latching mechanism to keep it down for a mechanical top.
  5. lilwarlock
    25
    26
    Jan 16, 2013
    MA
    Local Time:
    9:40 AM
    1965 Dodge Dart
  6. 65 Dartman
    65 Dartman FABO Gold Member FABO Gold Member
    12,603
    4009
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    9:40 AM
    The top bows and raising/lowering mechanisms are completely different. If you use the complete too assembly and weld the appropriate lift brackets in place, it can be done
