Cooling
Rodsaknockin
Canada
What kind of rads are you guys using for a small block oem,aluminum , or a rad shop custom built thanks in advance
I ordered a 26" from O, Reilly's for about 200 bucks.
It did require drilling new mounting holes though because of it's width, but at least I have radiator core over the entire opening.
Ok I will have a look there thanks
Just tried to check that out and the page can't be found. I will check on the computer and see if I have any luck thanks
