correct oil pan # ?
66dartgt
chgo suburbs
What would be the correct pan number for a 73 dart sport 340 ? The one I have is a #228, does that sound right ?
Should be pretty easy to find one.
Part # 3614227
Usage: 70 to 74 E-Body, B-Body A-Body and C-Body with 318.
70 to 73 E-Body and A-Body with 340.
71 to 73 Charger and Satellite with 340
Dave is right on the part #3614227
According to a list I have it has the 228 stamping on it.
???? I have no Idea why its one off ????
Mopar Numbers
Tables: Oil Pans
A/LA Pans
Stamp---Part#-----years-------Body-----LA Engine----Baffles---Notes
228----- 3614227--1973-1976--A/B/C/E--318/340------No-------strainer
charger70 Do you have the part #'s for the oil pan prior to 73 ?
Good info you posted....thx
OK heres what I dug up for 66-72 LA
Stamp--Part#----years-------Body-----LA Engine---Baffles---Notes
394----2806393--1966/1969--A/B/C---273/318/340---No----strainer#2468849
294----3418293--1970-1972--A/B/C/E--318/340------No----strainer#2468849
Thanks - I was digging around in the attic and found another #228 pan, its from a 73 318, so apparently 318 and 340 pan #'s are the same that year. I know for certain that both came from the respective engines now.
