hi, my gauges all work beside my temp one. i have a 66 cuda formula s.
i bought a new sender from ebay that should be for my cuda. i measure the resistance in cold 225ohm and in operation it has 33ohms. somewhere i read that the sender operate 73-10ohm.
do i get the wrong sender?
if i connect the the cabel from the sender direct to ground. the needle moves fast to hot mark. of course i switch off the ignition after it moves to hot to prevent a burned gauge.
please let me know the correct part nr.for the sender i have to use.
thanks and greetings from vienna
