Thanks for the reply Rainy, I did look at that pad but there are no numbers visible there at all so I can't match the vin. And Geof thanks for the info, those numbers are hard to read but it looks like PK4058302 6177 then either 4300 or 4350 can't really tell no build sheet so it doesn't look like that will work. This trans that I got with this car is a 727 and the PO had it mated up with the 1971 340 motor that I got when I bought the car also. Karl sent me a chart with a bunch of numbers to match up what this trans did come in from the factory only problem is that the numbers on this trans are not on the chart that he sent. The numbers are very clear so I know that I am reading them right, they are 3743102-2 if anyone else has a chart that can tell me what it came from please chime in. I also know that this is not the trans that came from the factory because the yoke on the drive shaft does not fit the trans so I am guessing that this drive shaft is for a 904 trans. One more thing, after reading about trans swaps it looks like the cooler lines and linkage will all work from the 904 to the 727 the Scamp came with the 727 trans mount which says that's what I need to install it, but I will either have to find a 727 yoke, put it on this drive shaft and have the drive shaft shortened or find a A body 727 drive shaft.
Thanks for all the reply's from everyone.
Bob
