Corrected Horsepower Factors > 340 ~ 360 ~ 383 ~ 400 ~ 426-S ~ 440
1962
383/343 HP ............ 320 HP
1963
383/330 HP ............ 280 HP
1964
426/365 HP ............ 300 HP ..... 'Street-Wedge'
1965
1966
383/325 HP ............ 280 HP
1967
383/280 HP ............ 280 HP ..... A-Body
440/375 HP ............ 350 HP
1968
340/275 HP ............. 299 HP
383/300 HP ............. 295 HP ..... A-Body
383/330 HP ............. 295 HP ..... B-Body
383/335 HP ............. 300 HP ..... Road Runner and Super Bee
440/375 HP ............. 356 HP
1969
383/330 HP ............. 295 HP ..... A-Body
440/390 HP ............. 395 HP ..... 'Six Pack' and 'Six Barrel'
1970
340/290 HP ............. 320 HP ..... 'T/A' and 'AAR'
440/390 HP ............. 405 HP ..... 'Six Pack' and 'Six Barrel'
1971
340/275 HP ............. 314 HP
440/370 HP ............. 350 HP
440/385 HP ............. 405 HP ..... 'Six Pack' and 'Six Barrel'
1972
340/240 HP ............. 285 HP
400/255 HP ............. 305 HP
400/265 HP ............. 320 HP ..... w/'Fresh-Air Package'
440/280 HP ............. 340 HP
440/290 HP ............. 345 HP ..... w/'Fresh-Air Package'
1973
400/260 HP ............. 298 HP
1974
360/245 HP ............. 305 HP
400/250 HP ............. 310 HP
440/275 HP ............. 345 HP
Note; The 1972 {400 and 440} Engines were available with a Fresh-Air Package.
Note; Calculated to be worth an additional {+10 HP} by the Factory.
1962
1963
1964
1965
1966
1967
1968
1969
1970
1971
1972
400/265 HP ............. 320 HP ..... w/ 'Fresh-Air Package'
440/290 HP ............. 345 HP ..... w/ 'Fresh-Air Package'
1973
1974
Note; In 1972, the {400 and 440} Engines were available with a 'Fresh-Air Package'.
Note; The Factory 'advertised' this package as providing an additional {+10 HP}.
Plymouth Road Runner
Note: {Code; N-96} 'Air Grabber' was available with either the 400 4-Barrel {Engine Code; E-68} or 440 4-Barrel {Engine Code; E-86}.
Dodge Charger
Note: {Code; N-96} 'Ramcharger Hood' was available with either the 400 4-Barrel {Engine Code; E-68} or 440 4-Barrel {Engine Code; E-86} when the
'Rallye' package was ordered.
i did read a Dulchic test on a 340 built to stock specs including original carb
...it produced 281 hp.and they claimed the original carb was not working correctly.
Then added a bigger (800?)carb and it jumped up to a bit over 300.
..it seems a sharply tuned 340 could indeed hit 300
adding the thermoquad should show a nice gain over the stock small AVS.
those numbers are probably very close...i love these posts
I remember when Dulcich had a monthly column in Mopar Muscle. I used to love the comparison tests and sleeper combos he did. One thing I remember is that the 340 seemed to love bigger carbs. Throw the carb size calculations out the window and run a T-quad.
I always said the 1971 340 may have been the best in an A-body. It still had the high compression and an 880 cfm carb when needed. The AAR T/A may be rated higher but they were in a heavier E-body. My best friend Rick ordered a 1972 (first year for low compression) 340 Duster, 4 speed and 3.23 SG. We took it to the track in the spring when it was new and it ran a 14.51 on its only run. RIP Rick, Vietnam vet who died of cancer 10 years ago.
You know, many years ago I broke down the numbers on the 340 and 360. I examined all the horsepower and torque figures gross and net. I discovered the 74 -360 made more power than the 340 and these numbers show the same story. Except for 71 but my numbers showed more torque for the 360 even over the 71. Don't want to start the 340-360 debate but it's interesting.
The Duster 360 did a number on those in the NHRA 'Back-in-the-Day'.
Judy Lilly ~ 1974 'Duster 360'
1974 ..... SS/MA
1975 ..... SS/LA
1976 ..... SS/KA
The NHRA did their best in trying to squeeze {Horsepower change} Judy out of Super/Stock each year by upping the 360's Horsepower factor.
