Hey guys just in the middle of converting my dual point dizzy to pertroix ignition. Can remove the wire in the picture seeing I am not running points anymore. Although I might have the points for backup. And second I took my vacuum advance can off to clean it and noticed it had what seamed like gas in it.. I did flood the engine ladt time I had the car out. And how easy should the vacuum advance arm to push in by hand? And is there a way I can bench test it? Thanks
