crack in dash cover..
grassy
Nova Scotia
Just noticed a small crack (1/2 inch) in our dash pad cover in the corner.
Is there any glue or something that we can apply so it won't get bigger ?
Thanks
Ian.
Thanks
Ian.
I have used weld-on # 16 to stop the crack from traveling. Be warned that darn stuff WILL melt the heck out of your dash pad if you just glob it on there. I used a tooth pick to put it in the corners to seal it up.
it is a solvent cementand pretty darn strong. I use it to permanently bond vacuformed ABS together for my custom console for my car.
[ame="http://www.amazon.com/Weld-On-Acrylic-Cement-Capacity-Clear/dp/B003HNJEY0"]Weld-On 16 Acrylic Cement, 5 oz Capacity, Clear: Contact Cements: Amazon.com: Industrial & Scientific[/ame]
