[WANTED] Tailgate window switch dash trim
NSdartSW
Southern California
Rating - 0%
0   0   0
I know this is an incredibly niche piece I’m looking for but my ‘66 Dart wagon has the power window tailgate but the switch has been moved down under the dash. I have the dash trim cover for the switch to go into the dash again but it broke at some point before I bought the car and the little pins on the back are long gone. I have been able to find literally nothing I barely even found replacement switches for the power tailgate window(thankfully mine still works) so I figure I’d toss this out into the blue in the small chance there’s one out there. If any one has suggestions to fixing the cover piece have that would be very welcome as well.
Much appreciated, thank you
Noah
I’m currently at school but when I get back home I post a picture of what I’m looking for, sorry not sure that’s what I’m looking for.
My '66 has the switch in the dash next to the heater and fan controls- a dedicated dash piece, not an added-on bezel.
Yeah, I know it looks different from stock- I added the woodgrain and the radio was cut in the past for an AM/FM, so I just cleaned up the cuts and rolled with that.
BTW, the wagon window switch is the same as the switch for power convertible tops.
As a matter of fact the dash trim is the same, too- if you don't mind the switch being labeled "top" instead of "Window". Either one is a pain to find though.
Oh really I did not know the switch was the same thank you. I have the little piece but it looks like someone broke the little pins taking it out. I’m half tempted to roll with the convertible switch that I could actually find.
I guess I don't know what you mean by "the little piece", mine is all one solid dash panel.
Possibly a difference between 170 and 270 series wagons? I don't know; mine's a 270.
I have a 270 as well but the dash piece that says window. At least for what I have it’s the little bezel that pushes into the rest of the dash panel with 2 little pins and the pins have been broken off. Sorry for not being very articulate
Pictures may help. One of us might fall into 1 at a cruise-in. Maybe not just in time for Christmas but never know. Aftermarket relay kit could extend the life of your OEM switch or a new switch.
