[Found!] Cragar S/S wheels
Odin
Terre Haute, IN
EDITED - I am looking for a good set of staggered 15" Cragar S/S Wheels in either 08/61 unilug or 61C direct drill for 5-4.5 LBP. I want two 15x8s for the rear and 15x4.5 or 15x6 for the front. I need the offset to be as close to zero as possible (plus or minus 6mm) except on the 15x4.5s
I have a set of pristine 15 x 8 w/4.25 backspacing. (out of the box specs).unilug. They were on my Hemi Duster when I first built it.....upped to 10s when I realized my tires needed a wider rim.
Got maybe 100 miles actually driving on them....never in the rain or weather.
Like to get $250 plus the ride for the pair.
I believe the 08/61 are unilug with 4.5 BS and the 61C are direct dril 5-4.5 with 4.25 BS. Can you confirm which type you have? I only ask because I want all four to be the same type when I’m done.
I will snap a picture when I get home....I know they are unilug.....99.9% sure they are 4.25 backspacing but I will confirm.
can I e-mail them or text to you?....PM me your info if that works....if you cant because of FABO rules, send me a text or e-mail and I will respond.
Denny
hemidenny@rocketmail.com
304-939-0097
I have a set of pristine 15 x 8 w/4.25 backspacing. (out of the box specs).unilug. _ _ _ _
Got maybe 100 miles actually driving on them....never in the rain or weather. --
Like to get $250 plus the ride for the pair. --
-- PM sent.
I have a brand new set of 14" SBP Cragar S/S wheels with left and right hand lug nuts I need to sell. I know they are not what you are looking for but I thought I would throw them out there if someone was looking.
