[SOLD] Crane aluminum roller rocker arm setup, 1.6 ratio, B/RB engines
physixx
Edison, NJ
I have for sale a used set of 1.6 ratio Crane aluminum roller tipped rocker arms for the B/RB engines. This setup comes with the chrome rocker shafts, adjusters, attaching blocks and hardware, the spacer springs along with the shims to adjust the rocker tips to the valve stems. These rocker arms are in decent shape with 8 of them offset .015” to the left and 8 to the right. The only problem with this set is that one of the rocker arms was damaged at the roller tip and is not fixable so that needs to be replaced. In addition, all the parts with threads have been cleaned. Everything else is excellent. I would like to get $125.00 for everything plus the shipping.
Ken
Edison, NJ
