Crane Gold Roller Rocker Arms
ATroll2
Member
Hill Country of Texas
I recently had someone work on my motor. I have had to go back behind them to fix a serious issue with my valve guides being too tight after a refresh job. Now I am not sure as to which way to set the Crane Roller Rockers on the heads. I can't find my paper work but it seems as if there is only one way to install them correctly. On one end of each shaft is a half moon shaped notch. It seems to me that that notch is supposed to face the front of the vehicle. Any help out there?
1970 Duster "Earthpig"
Small Block with Eddy heads!
the notches will always be to down and to YOUR left....
meaning the driver side the notch will face the front of the car..and passender side the notch will face the firewall...
this will put the oil holes down and towards the exhaust...
Tony,
Thank you for your help8). I will get them on today. Couldn't remember to save my life but will write this info down for the future....tough getting OLD and Forgetful.=P~!
