ATroll2
I recently had someone work on my motor. I have had to go back behind them to fix a serious issue with my valve guides being too tight after a refresh job. Now I am not sure as to which way to set the Crane Roller Rockers on the heads. I can't find my paper work but it seems as if there is only one way to install them correctly. On one end of each shaft is a half moon shaped notch. It seems to me that that notch is supposed to face the front of the vehicle. Any help out there?
1970 Duster "Earthpig"
Small Block with Eddy heads!
