Crank
f55079
massachusetts
Where are the casting #s on the crank or how do I tell if it's forged or cast? Thanks
OK I get it. The forged comes with a double roller timing chain sprocket! Or, am I wrong?
Hi Rob.
The forged cranks will have smooth edges to the counterweights, the cast cranks will have sharper more squared off edges...
Caint tell 100% but it does look forged. The number should be on a counter weight somewhere.
Should be a longer number than that.
That's a stamping. Not a cast number. The numbers you're looking for have positive height off the crankshaft. Although this is a cast 360 crank, but like this:
The OP's crank is forged , there are not usually , I want to say no but then someone wiil produce one , numbers on a forged crank , the stamped numbers were added by someone .
