rustytoolss
I've got a crank from my 66 273. Can I install it into a 1984 318, without rebalancing the engine assy ? Any other things I should know ? What about reusing my 273 rods into the 318 ?
Yes, it can be installed in the 318. Yes, you should balance the rotating assembly. Yes, you can use the 273 rods. The issue is the small diameter torque converter register on the 66 crankshaft. The 68 and up transmission torque converter/transmission won't fit. 65'
