belmateo
Are all big block cranks the for four speed and automatic?
Not sure exactly what you are asking. Simple answer is yes, however if for instance you take a 440 out of say a '74 Fury with a 727 and try to put it in a 4-speed car the pilot bushing most likely will not fit. Have the crank bored or do like I did and spend two weeks with sandpaper in the crank bore and taking down the bearing a little.Are all big block cranks the for four speed and automatic?
