1000 miles?? let me know how it runs after 10,000 miles who is maund motorworks never heard of them b4, and the OP was requesting a crate 318. And I agree jimjim see if you can find a MOPAR shop, I left that out...i bought a 360 crate motor from maund motorworks put 1000 miles so far trouble free
I am not picking on you or your motor, I hope it runs forever, but after doing a 5 minute research on Maund Motorworks, who sells thier engines on Ebay, I found this:he is an engine builder in pa he specializes in chryslers he lists a 318 on his website
I...found out it was a BIG BLOCK OIL PAN ON A SMALL BLOCK ENGINE. ...
the drivers side mount on a 360 is different and requires a "conversion bracket to bolt to a 318/340 K member
No, the 360 and 340 have a drivers side mount that is slightly different than the 318 mount.
You can use the 318 mount and use a spacer on one of the three bolts on your existing motor mount bracket. Something like between a 3/8" and 1/2" spacer. The other two bolts are fine.
