crazy question about my 73 duster
73 duster340
Member
north jersey
i put on stock 14" rims with a 4" back with e-70 14 goodyear bias tires. looks great but here is there weird part. from edge to edge of the rear tires, the measuement is 62 inches. when i do the front, it is 66 inches. tha translate into 2 extra inches on each side for the front. could my rotors be wrong in the front? when you look at the car, it does not look right. am i crazy?
In 73 the A bodies began using the B/E body brakes and spindals...
this change the front track...yea...it is wider then the back
thanks. it just does not look right. also put back the original leaf springs. the pair i bought from mancini raised it up too much. looked bad. still sags alittle. might see if i can get the drivers side from them monday and use 2 driver side leaf springs they are an inch and a half lower.
i always hated how the rear track is narrower than the front.
