wildbill
I am currently building a 75 duster for bracket racing at Firebird raceway in Idaho (2700 foot elevation) - will not be street legal. Gutted with a single racing seat. 10 point mild steel cage already installed. Approx 3000 pound race weight? Hoping to run at least well into the 11s with this combo. Let me know if this sounds realistic before I go any further - only the short block is built at this point.
8.75 rear with 4.56 gears and a spool
Full manual 727 with transbrake
~3500 stall
360 - 0.030 over
KB 107 pistons (approx 0.005 in the hole)
0.026 Mopar performance head gaskets
IMM RHS heads with 62cc chambers
About 11:1 CR
Hughes or Comp pro magnum rockers (any suggestions which would be better?)
Lunati Voodoo solid cam (PN 30200742)
Advertised Duration (Int/Exh): 280/288
Duration @ .050 (Int/Exh): 251/259
Gross Valve Lift (Int/Exh): .566"/.586"
LSA/ICL: 110/106
Valve Lash (Int/Exh): .016"/.016"
RPM Range: 2800-7000
Edelbrock Victor intake
Holley 750 DP carb
100 horsepower nitrous system (if needed)
~3500 stall
360 - 0.030 over
About 11:1 CR
LSA/ICL: 110/106
Holley 750 DP carb
