CROWER CAM any one have this ? 440
1994rm250
PortWashington , NewYork
Just pulled my cam Crower says they cant find it its eather Y5125 or EP-45 For a 440 ? i Mic'd it up at 330 x 1.5 rocker ratio wich is 495 lift is that correct ?
I looked for a while, but couldn't find anything even close. Cracked has the best idea. Silly question, are you sure it's a Crower? I believe Engle uses an EP prefix on some of it's cams.
Is the EP-45 in the shaft or stamped on the end? If it's cast in the shaft it is probably a foundry number, I believe most cam grinders stamp there info on the ends of the cam.
Good call arrow. Call engle cams because they used that prefix
(562) 232-7079
A Crower cam will have "Crower" spelled out on the end of the cam. They make a big deal about that on their site.
It's stamped in the camshaft shaft, it's still in the engine. I'd like to find out if it's anything good or if I should just replace it while it's out of the car and out on the stand I looked and engles website and havnt found it I'll probally have to call around. Figured I'd see if anyone else might have seen or heard of this cam before I just pull it and buy another.
The stamp is on the shaft of the cam I bought the longblock and was told it was rebuilt but the previous owner died so the guy new nothin about the engine other than it was rebuilt so I pulled it apart to see how it all looked it's a low compression 77 truck engine but i figured I'd run it as it sits just wanna make sure the cam will be ok with the low compression, and if not change it before I put it in my 70 duster.
sorry just got back on here , it says crower on the cam , i called crower , and also had my boss speak to dave crower him self the cam is from like the early 90's , and dont have any info on it , they only keep records for 5 years or so
...........I have 2 crowers............33207 and a 33208...........great cams......they say crower on the 1`end along with the #s.........kim........
